I heard about these awhile ago, they were originally designed to improve on the star specs by maximizing the surface area of the the contact patch resulting in lowering the operating temp of the tire so they can run a softer compound with less proprietary blends of tire hardeners. The star spec was originally designed to be an aggressive street tire that got good treadlife in doing so they used a tread compound that had less "tire-hardeners" then a regular all season/UHP tires but contained more then an r-comp. Unfortunately in doing this it leaves the tires more prone to "chunking" or "graining" (when the tire is brought up temp to fast/overheating temp to fast, cooled, then back up to temp in the same manner and result in damage by chunks of the rubber coming off of the tire)
This tire is suppose to be their version of the RS-3 killer but I think it will be a close match up. While at the same time manufacturers are aiming to now take down the likes of NT-01s, R888, and the RA-1 with Hankook coming out the TD (a.k.a. Trackday) in 3 or 4 different compounds, Federal with the FZ-201 and 202, and maxxis ZR9 Victra. It is also rumor of bridgestone and yoko redesigning the RE-01 and AD08 as well.
Most of these tires have not yet reached the U.S. of A just yet but are being tested or have been out and available overseas already and some are due to be released sometime before this summer till next year. Looks like I'll be busy testing all these new goodies![]()
