The idea is to put them somewhere with lift, or negative pressure to pull air out.  If the are even or behind the hood hump, they are not working or sucking-in air.
You would, I don't.  Removing a thermostat does not increase cooling efficiency or capacity, it unnecessarily increases flow.
Lots of people think they understand aero, most don't.  There is incredibly high pressure at the cowl/back of the hood.  If you open the hood there, it will always increase air-flow into the engine bay, increasing pressure in that chamber, and decrease transition or movement of air through the radiator.  That's not open to debate, that's a fact.  The extra opening in the bumper is stupid.  There is no problem with volume entering the mouth, the problem is pressure differential.
See that little dividider/foil in the mouth of the bumper, under the top-side of the mouth?
It's 1.25-1.5" below the top of the mouth and that effectively cools a 400hp Miata in 105* desert heat at WSIR on the big track.  Do you think you need 20x-40x more airflow than that car at a measly 230whp?  Matt also ran a 190*f thermostat in that car.
That bumper hole in your car does nothing more than dump unnecessary air between the interooler and radiator, significanly reducing intercooler performance.  You're call will make a ton more power without that extra hole.
Your radiator is the choke point.  Building a chamber from the mouth to the radiator will increase pressure slightly higher than the incoming air, further helping the radiator cool.  This is why you want the orifice to be smaller than the negative area of the radiator (area of the radiator - fins and tubes).
Before you ask, fans will reduce the efficiency of the radiator.
You need to seal the front of the radiator and be certsin your un-trimmed belly pan is in tact.  Step one is sealing the front of the radiator, step two is assuring you have clean-airflow back to the front subframe, step 3 is closing the front bumper vent.  I know I've been up your ass about this, but it's time for you to fix the car, the right way.  Remember when I told you to do this yourself because no shop you or I can afford would do this right?  I do.  :)
Please remember that when my car made 50hp more than yours I could flog it in 105*f heat at HHR which is a slow course, tucked behind a Panoz for ~45 minutes, and never go north of 199*f on the water and 230*f on the oil.
The taper is reducing efficiency.  If you ever build them again, get the air away from the rotor surface and into the hub.
Aero 101 is complete.
If you guys want some sweet aero articles from Racecar Engineering, let me know in email.
