Results 1 to 14 of 14
Thread: Engineering problem
    Default Engineering problem
    I have a 10x12 wood Tuff shed from Home Depot that I bought a few years ago. It was built on a slight incline and the shed was put on concrete blocks which are aligned around the perimeter in 6 places and at least one location in the middle. The blocks have sunk into the ground causing the door to not open fully. I need to raise the shed up enought to get more blocks underneath. Has anyone done this? Any tips would be appreciated. I was thinking about jacking up the back putting more blocks in the middle first so I could easily tip the shed back to put the blocks on the uphill side then go back to jack up the downhill side to put the blocks in the back. Also the shed has the galvanized steel frame that sets on the blocks.
    You are going to need to go old school think this:
    I was thinking about buying or borrowing a Harbor Freight farm jack since I have steel frame on the bottom. I believe my neighbor has access to one.
    Don't you have a kid? Get him to do the heavy work while you slide the blocks in place.
    I have a farm jack you can borrow.
    This thing weights at least a thousand lbs! Looks like you need to spread load between the bloks and the soil. The ground around where we are is just too soft. If you don't, in a couple of years you will be in the same situation.
    How about an air bag? Maybe just an old inner tube, if you can find one.
    Jul 2004
    Collinsville, TX
    How much do you need to move it? Would driving shims in between the blocks and the building get you there?
    http://www.homedepot.com/s/wood%2520shims?NCNI-5
    Dave
    "Opinions are like ..."
    ^If you do shim it, I'd use something synthetic like Trex decking or such.
    Good stuff. I plan on building a pyramid in my backyard with those techniques.
    When the foundation 'crew' leveled my house, they were using simple bottle jacks. not sure if digging around those supports is more work but they made it look simple.
    95 r white
    We recently jacked a significant portion of my house to replace a water damaged footer... My 2 ton harbor freight ultra-low jack performed admirably...
    I am not too worried about the ones on the outside. Its those pesky supports in the middle under the floor that will be more challenging.
  1. window problem, door problem, and query about the front end
    By Rufus in forum Miata Tech and Chat
    Last Post: 08-01-2010, 12:02 AM
  2. some unique engineering
    By Mathews2004 in forum Bull
    Last Post: 10-01-2006, 09:40 PM
  3. Hey engineering types, would this work?
    By srivendel in forum Bull
    Last Post: 04-28-2006, 04:32 PM
  4. Engineering job openings FYI
    By altiain in forum Bull
    Last Post: 02-14-2006, 01:01 PM
  5. Engineering jobs?
    By EvilSpeeder in forum Bull
    Last Post: 07-01-2005, 03:37 PM
