Results 1 to 10 of 10
Thread: NB Rear Brakes
    Engine Builder rootdown_53's Avatar
    Nov 2005
    Probably under a car...
    Default NB Rear Brakes
    Can anyone out there post some pictures of the springs on the rear brakes of an NB Miata? I took all of that extraneous crap off of my '99 a year ago, and now, because I'm a glutton for punishment, I'm trying to put that stuff back on...but I can't seem to get it quite right. TIA
    i need a better phrase...
    Springs? Most Miata's have 4-wheel disc brakes.
    Chassis Designer
    Mar 2010
    keller, tx
    the m springs?
    Nov 2005
    yep, those pesky little m springs. i keep thinking i know how they are supposed to be installed, but they don't seem to want to stay in place. now, naturally, i assume i'm doing it wrong.
    Chassis Designer
    Mar 2010
    keller, tx
    i took mine off since it only had one on from the previous owner. they aren't necessary but they do eliminate some noise
    i don't remember how i placed them, but with a picture it shouldnt be too difficult to manage
    Nov 2005
    thanks for the pic, i'll compare that to how i was trying to install them.
    on a related note, has anyone had experience with front brakes that drag? i have greased the pins and even rebuilt the calipers but the fronts are still dragging. i have had them apart twice this morning, i can't see anything wrong though...
    Nov 2005
    the picture worked! it took me just a few minutes to get the m springs installed the right way once i saw the photo. thx wolzen
    Chassis Designer
    Apr 2009
    Keller, TX
    Disc brakes drag, by design. There is always a little pressure in the hydraulics to keep the pads nesettled up against the rotors. My 2006 seems to oscillate between a little pressure and enough pressure to keep the car from rolling down a slight incline. Nonetheless, you might want to take a look at the flex lines. If they're clogged, they might retain too much pressure to the calipers. My friend destroyed a rotor on his Chevy truck because of a clogged flex line.
    Nov 2005
    roger that, i'll give the lines a look. i know that there should be some drag, but i'm actually hearing them drag when i drive next to a solid surface (building or fence) that relfects sound. i never heard that until recently...
  1. Carbotechx12 rear pads Nb sport brakes
    By jeff_man in forum dfwMiata.com Classifieds
    Last Post: 02-21-2010, 05:23 PM
  2. Brakes
    By ken o in forum Miata Tech and Chat
    Last Post: 12-17-2009, 09:25 AM
  3. Bigger Brakes for my '91
    By prontophil in forum Parts is Parts
    Last Post: 11-30-2007, 11:36 AM
  4. brakes & rotors
    By mia-t in forum Miata Tech and Chat
    Last Post: 08-22-2006, 02:29 PM
  5. Ruststang Brakes
    By black roadster in forum OTM Tech and Chat
    Last Post: 09-29-2005, 07:52 AM
