New electrical gremlin: hi-beams
Just noticed this the other night. If I pull the lever to flash the hi-beams everything works normal, the hi-beams turn on. But if push the lever forward to switch to hi-beams only the lights turn off completely(the running lights stay on).
I know it's not the lights (I think??) because the hi-beams still work when flashed. I'm stumped as to where to look. If it was a fuse or relay wouldn't the headlights as a whole not work, or at least the hi-beams? Could there be a problem with the headlight switch?
