Ah yes... cya in a bit.
Torsen is in! ::EvilBana Gracias Señor Bean! With the exception of a small exhaust leak, the test drive was a success.
Quote: Originally Posted by Titus Gracias Señor Bean! With the exception of a small exhaust leak, the test drive was a success. You're quite welcome... anytime. Is the leak on that set of nuts by the cat?
Quote: Originally Posted by Treibenschnell You're quite welcome... anytime. Is the leak on that set of nuts by the cat? Don't know... I could just hear what sounds like a leak pre-muffler. I will check it out tomorrow.
Quote: Originally Posted by Titus Torsen is in! ::EvilBana Gracias Señor Bean! With the exception of a small exhaust leak, the test drive was a success. :clap:
Quote: Originally Posted by Titus Torsen is in! ::EvilBana Gracias Señor Bean! With the exception of a small exhaust leak, the test drive was a success. Haha, by test drive you mean you tortured the asphalt!!!! Did you do the donut test and the peg leg test?
