Forgot one. I need to replace the shifter boots and all that goes along with it. They have holes in them and when I'm on the high way, hot air blows through it like the heater is on...
I'm going to be doing a lot of maintenance in the near future. Where do you guys usually pick up:
timing belt and applicable gaskets, seals, etc.
water pump, belts, gaskets, seals, etc.
other belts (ps, alternator, etc.)
new hoses
fluids for transmission, diff, coolant
plugs, wires
bushings (I've only visually inspected the rear sway bushings so far, but they are SHOT)
I see that several online dealers have kits with some of the above...
Thanks for the help
P.S. of the above, which should get done first? I'm a tight budget so I can't do it all at once...
SOLD - '91 BRG
SOLD - '91 BRG
If you autocross twice a year, you're eligible for ordering directly from Mazdaspeed at discount prices.
If not, check the Marketplace on miata.net.
Check out moss motors
www.miatamania.com I've had good experiences with them before.
2004 Saturn Ion Redline
Wrong Wheel Drive
1992 Grey MX-5
Right Wheel Drive
http://www.buymazdaparts.com/model.cfm?modelcode=MIA97
Make sure to get the right T/B kit, you may have a small crank.
Have your VIN handy.
I'd do the T/B kit, waterpump, CAS, fan belts, hoses, and 33% coolant all while having the radiator out.
Also if the radiator is green, replace that too.
Don't worry about bushings, and urethane sway bushing come with new swaybars.
I checked the VIN before I bought the car, no short nose. :)
Thanks for the help guys. I guess I'll save up for all of those parts and do them at the same time. I'm sure that's a better plan, I'm just anxious to get started.
Maybe I'll start with a smaller project like the shifter boot replacements. It's too hot for the AC to be fighting the heat pouring in through the shift boot.
SOLD - '91 BRG
Speaking of Parts Mr. Rogue sir have you tried the Motorcraft® Full Synthetic Manual Transmission Fluid SAE 75W-90 gear oil?
I see it is all the rage on the pointy board!
Any thoughts on gomiata.com?
I think I can get the timing belt kit, water pump kit, and complete hose kit for about $275...
SOLD - '91 BRG
91 Civic Si Daily Beater
'99 Brilliant Black MX-5
Tien S-Techs, Torsen, Mazdaspeed Short Throw Shifter, Deleted cat, 01 exhaust manifold (cat delete), custom short ram, JR Plug Wires, Autopower Rollbar, 01+ bumper and smoked headlights with 6000K HID, tinted tails and corners, Enkei RSF-2 16x7 for daily and stock 14" for the track.
http://www.mazdaspeeddevelopment.com/partsprogram.htm
Its a sweet deal!![]()
For the timing belt/water pump change, I've seen lots of excellent comments on the big board about a particular eBay set. The seller name is theautopartsconnection. While I have no experience with this "kit" as of yet (my last such items came from Trussville Mazda), I am strongly considering using it for my next 60k update.
I put the fleabay timing belt and water pump kit in my 1990 and it worked fine. You can't beat the price!
www.mazdastuff.com if you can't do MazdaMotorsports.
Chris
http://austinmiata.com/
