Results 1 to 7 of 7
Thread: Fs:ss braided clutch line
    Default Fs:ss braided clutch line
    Purchased from Mazdaspeed Motorsports Dev. several years ago, never installed it, forgot I had it, bought another one last year and installed it. Part No. 000-02-5601. $35
    Does this make much of a difference on a stockish engine? I had an issue last autocross with my clutch slipping badly after a few runs. After debating it logically for awhile I've come to the conclusion that as well as probably bad technique, I may have been trying to shift too fast and the hydraulics line may be sloppy due to old lines/old fluid or whatever causing the clutch to engage a hair late. I plan to flush the fluid when I get a chance. If you think this might help my problem as well then you've got a buyer.
    1.8 engine with a 1.6 oem budget clutch on 1.6 7lb fidanza flywheel BTW. Clutch is 6 months old. Let me know.
    It replaces the rubber line that can expand a little with age, making for more precise hydraulic effort. Same principle as with the rubber brake lines that get replaced with SS braided lines-prevents the line from expanding under pressure so that all of your pedal effort goes where it is suppose to. Whether this item will help your clutch problem, I don't know for sure, but it certainly won't hurt it.
    Is this the straight shot line? If so I'll take it.
    Quote Originally Posted by ktdub44 View Post
    Not sure what you mean by "straight shot".
    I think he means the line that replaces the curly hard line as well as the rubber, vs the short line that only replaces the rubber.
    Sold
  1. I need a new line of work..
    By HudsonHawk in forum Bull
    Last Post: 05-05-2009, 06:09 PM
  2. Need Hydraulic Line for Clutch Slave Cylinder
    By motorollow in forum Parts is Parts
    Last Post: 01-27-2008, 10:05 PM
  3. Clutch engages early OR ...early clutch release point
    By joe.MIATA in forum Miata Tech and Chat
    Last Post: 02-11-2007, 02:15 PM
  4. Where do you draw the line?
    Last Post: 05-12-2005, 05:29 PM
