Results 1 to 13 of 13
Thread: Compressed air needs a filter!
    Default Compressed air needs a filter!
    So... I was wondering to myself over the weekend why my regulator wouldn't regulate... Which brought back lots of wonder about these super cheap little compressor/tanks jobs like the one parked in my garage that go tank, main gauge, regulator, output gauge... With no filter prior to the regulator.
    When the regulator worked over the weekend - and when I say worked, I could set a pressure, and it would leak down the main tank to match. Grumble... In any case... I could live with that until I made a trip to Harbor Freight or somewhere to get a cheapo filter/regulator combo befitting of the (ahem) expensive nature of this compressor.
    Not so tonight. So it was time to be a bit more forceful in dis-assembly of the regulator. I quickly discovered that the reason it didn't appear to be serviceable was because it had bonded itself together with mineral deposits. I don't remember pumping water through it, but who knows. In any case, a considerable quantity of CLR and some wire brush work later, I removed all the gunk. I replaced the two o-rings and silicone sprayed all the gaskets. I left off some decorative trim, and hit the power switch.
    Let's just say I was happy when I shot some oil in the oil hole and the blow-by pressure didn't shoot it back out.
    It's still a crapulicious regulator, but it works, as I said until I visit the Harbor Freight again. Remember kids... dihydrogen monoxide is bad. Bad!
    My compressor has, maybe, a little much in the filter dept. I have used it to paint a car so I figured this was adequate. There is a 10 micron filter on the left and a 5 micron after that before it hits the regulator on the right.
    You have to remember, as compressed air cools, water condenses. Hence the deposits in the regulator.
    The filters do a good job of removing most of the water, so I just periodically drain the water from the bottom of the filter.
    '06 RSX Type-S NBP
    Nice work! I wish I had room to mount stuff "onboard" my compressor like that to keep it portable, but it will probably spend the second half of its life as a truly portable tire filler and nothing else. Regardless of knowing how they got there... it was still a bit shocking to see all the minerals living in the regulator. Oddly, though... the minerals didn't kill it... A rubber piece about the size of a pencil eraser had lost its flex... and wasn't making a seal. Silicone to the rescue!
    Jul 2004
    Collinsville, TX
    Silly question... you do drain the water out of your tank occasionally... right?
    Dave
    "Opinions are like ..."
    Quote Originally Posted by Dave04 View Post
    Mine floats!
    First thing in the morning and several times during the day!
    Quote Originally Posted by sammm
    Mine floats!
    Don't want to find out if mine does or not!
    Jul 2004
    Collinsville, TX
    Dave
    It's my thread, Imma hijack it if I wanna!
    Quote Originally Posted by Treibenschnell View Post
    Every morning and several times a day...
    Quote Originally Posted by tailchaser View Post
    Echo! Echo... echo... echo...
    Jul 2004
    Collinsville, TX
    Mine floats!
    What of your's floats??? wait... don't answer that...
    Yeah yeah... you said it first...
    Dave
    Much like jeans... you have Levi's and Lee.
    One is the original, and the other a cheap knock-off.
    Or just too lazy to read.
  1. Air Filter & Insepction
    By gabkwong in forum Bull
    Last Post: 09-28-2006, 12:51 PM
  2. Changing the Oil Filter
    Last Post: 03-06-2006, 08:53 AM
  3. K&N or OEM Air Filter
    By jolberry in forum Parts is Parts
    Last Post: 11-02-2005, 09:47 AM
  4. Air filter for Spec...
    By channelmaniac in forum Miata Tech and Chat
    Last Post: 10-17-2005, 10:33 AM
  5. Oil Filter trouble
    By Darron65 in forum Miata Tech and Chat
    Last Post: 01-04-2005, 03:21 PM
