nealb here is a link for ya!
http://www.miata.net/garage/airbag_blink.html
Sure someone with firsthand experience can give ya some better guidance!
on a NA, the AIR BAG light on the dash flashes in a pattern
looks like 10 flashes then off, then repeat the 10 flashes
anyone have an idea on what that is saying?
or how to make it stop?
2009 MX-5 STR and track toy
Yeah,
It's saying the airbag computer detected a problem that wasn't resolved so it self destructed.
There's a thermal fuse wrapped in a heating element that the module will activate to commit suicide.
Your choices:
1. Replace the module.
2. Remove bulb from dash AND unplug the airbag computer & backup power supply.
3. Do #2 and put in an aftermarket steering wheel to get rid of the airbag there too.
Basically, if you remove the bulb, the airbag computer will beep like mad so you have to unplug it. If you don't remove the bulb but unplug the airbag computer then the bulb will stay on all the time....
so, if I do nothing, it will never go off in a crash, but the light will blink forever?
any other ramifications to the "do nothing" course of action?
Ooooh... heat shrink... THAT'S a good idea! Sounds like I'll be taking that course of action this weekend.
BTW, is it fair to say that a good number of Miatae have airbag malfunctions? Seems to be a common theme here...
...as for the bean consumption and the ensuing climate problems, maybe a charcoal filter would clean things up a bit...![]()
I looked at the link POS Racing posted up and it said "(System-down fuse burned)" So I'm taking that to mean there is some sort of fuse for the airbag and it is burnt out....so why dont you just try replacing it.
ahh see I glanced over your post to quickly...that would be my problem. Any idea how much those run from the dealer?
They don't sell internal components for the airbag computer.
Your best bet is to buy a used one from a wrecking yard. If it flashes a 3 or 4 error code then you can replace a few capacitors in it to fix it. I've done that before on those pesky airbag computers.
Once it flashes 10, it's dead.
