http://forum.miata.net/vb/showthread.php?t=364151
I'm already in... woo-hoo...
I am in as well. Thanks for the heads up. Has anyone seen the difference in light quantity and quality between these Bosch and Cibies or Hella e-codes?
Only know what I've read. Reports say that output between the Hellas and Bosch units are comparable. Cibies are a little better but at a higher price point.
http://www.flyinmiata.com/groupbuy/
http://www.flyinmiata.com/Store/images/28-17050.jpg
e-code lighting conversion
1990-97 Miatas can benefit greatly from a set of good reflectors and H4 bulbs. We've come across a great deal on Bosch E-Code reflectors, so we're passing it along to you. These reflectors usually sell for around $75 each, and we've managed to package them with bulbs for $50/pair. That's two reflectors and two bulbs, everything you need for one car.
It's a killer deal - but we need to buy a lot of them to make it happen. If we can't get 50 orders in this group buy, we won't be able to get the price. Tell all your friends, these will fit any car with 7" reflectors. Keith's going to put a set on his MG. Bill's putting a set in his Opel GT and 2002.
TWO E-code lights, w/55/60W bulbs, ready to bolt in.
Every 1990-97 Miata should have a set.
28-17100
Ends Feb 28,
Looks like it's time to upgrade the knockoffs to the real deal!
Im in, I hope we can get all the peeps for it.
they already have close to 150 people less than a week into the group buy. they ordered 240 sets already based on the huge reply they got, lol.
So what are the downsides of e-codes? You may have to replace with OEM at inspection time? What about "flashing"; that phenomenon that blinds oncoming traffic when you hit a bump. Is that only HIDs-type setups or these too? And bulb replacements can be had anywhere in different colors I hear, so the plug I guess is "universal"?
Thinking hard about a pair of these, but to be honest, I don't do a ton of night driving and hadn't really noticed my OEMs sucking. I can recognize a great price though, and with so many people jumping on this, I feel I need to look into it more.
Regards,
Piff
One disadvantage of these is that mine are now on backorder from FM. Awesome.
Otherwise, there is no downside to E-codes. You won't have to replace anything at inspection time. The light is much brighter, and the pattern is much more well-defined. Properly-adjusted lights won't blind any oncoming traffic. The bulb is a standard H4 bulb that you can buy down at VatoZone. They are plug and play in your Miata.
The main difference is in the reflector and diffuser, not just the bulb. Once you try them, you'll kick yourself for not doing it sooner - regardless of how much or little night driving you do.
Jump on it and wait...
they aren't backordered in the traditional sense. I think the software just says backordered when you order. They weren't going to order them until they had enough people..... although I'm not 1005 sure of that. Original date for the end of the group buy was end of feb. They only just placed the first order as far as I know.....
I got in on this and they told me they are getting the whole shipment in this week and should be sending them out starting next week.
Mine showed up today!
If they are anything like my Hella Ecodes I would be getting another set if my car was an NA model. Those combined with PIAA bulbs had awesome output. Unfortunately with my coilovers set to slammed on my '97 I did get some bounce on really bad roads. I'm sure I probably nearly blinded a few people on night runs.
i installed mine this afternoon. They look fantastic... I think I need to re-aim my headlights though....
Got mine today. Gonna see if I can make time to get them in this weekend.
The random times I get back to dfwmiata cost me here...too late!...But an internet search took me to another group that was getting in on the group-buy too. Someone from the Bus Depot (they do VW stuff - especially the VW Bus/Van?) chimed in with this link. Their price is apparently pretty close to this all the time and they matched up. Never heard of them before, but I think I may give it a shot???
I'm assuming that link will eventually die, so this other one may be better then. It's the spot on their site for just the headlights @ $44/pair. They'll sell you a couple of German H4 60/55w bulbs for $3.95 each so that would end up being a little over $50, but not much.
I ordered mine for the $50 package deal and it's going to end up being right at $58 with shipping. I'll let you know how it comes out...
Installed my new lights yesterday afternoon and had a few observations...
1. Mine had "MOTORCYCLE" molded into the lens (Motorcycle? Hmmmm... doesn't seem to make a difference, though).
2. The lenses are almost flat compared to my old Indian e-codes (i-codes?).
3. The light is more focused vertically, throws a wider horizontal beam, and has a much sharper cutoff. I took a picture of this, and as soon as I find my card reader I'll upload it.
So, my old e-codes were a big improvement over the best sealed beams I could find, and these new lights are a marked improvement over the old e-codes. Money well spent!
yeah. they are fantastic. dunno how closely you follow the pointy board, but it was discussed that these were actually bosch motorcycle lights. the difference is with the cutoff-- which i really like. these things are really bright and focused. if it helps there are also some good aiming links in the pointy thread.
You got a link? I'm too lazy to search and don't want to get yelled at over there... ::Banana::
EDIT: Found a LINK to something that looks informative.
ask and yee shall recieve.....
I'm easily confused, so I used this link
http://www.humanspeakers.com/audi/headlight-aiming.htm
There is also a more in depth precise method here-
http://www.danielsternlighting.com/tech/aim/aim.html
