The polarization of the magnetic field will determine the direction of rotation.
Fleming's left hand rule linkie
I just restored a vintage box fan for my wife.
In doing so I disassembled the electro-magnetic motor, cleaned it out with brake cleaner, electric contact cleaner, let it dry and then greased the moving parts with dielectric grease.
Finally I rewired the switch and plug.
The fans runs smoothly but also runs backwards.There is very little air coming out. I though I might have reversed my contacts. As a quick fix, I just flipped the non-polarized plug in the socket but that didn't do anything.
Any ideas?
Here is a schematic of whats going on.
Turn the fan around.![]()
Flipping the plug won't matter with AC. You somehow changed the polarization of the motor. Did you remove and clean magnets?
