What would be a good exhaust system for a 2001 miata? I'm looking to do some bolt-on work to get this thing a little faster![]()
i don't like the sound of Racing Beat. http://enthuzacar.com/ are very nice
				Awesome! Where is TDR located? I would like to stop by and check it out!
Try this.
				Well my plans are for intake/headers/exhaust. Just thought I would start with exhaust. But thanks everyone for input :) I will put all the advise to good use!
For the NB, the header give you the biggest gain and high flow cat is next. I had the intake and exhaust done on my 99. With that combo mod, I am hard pressed to say I gained more than 2-4 HP. Adding the header, my butt dyno tells me that I have added 5-8 HP (I have to qualify this statement, since doing this mod I eliminated one of the two CATs ... mine is a CA car). Finally, when my OEM CAT gone to heaven and adding the GW high flow CAT, the entire combo adds at least 10-15HP!![]()
I have a '01. The '01 has a stock tubular header that is desired by the owners of '99-'00's as a good replacement for their cast manifolds. Not very much to be gained from the '01 stock header to a aftermarket header. I did it anyway and went with the Jackson tri y. The only reason I did not go with the Racing Beat 4to1 was because it would not fit with my planned supercharger later. I then replaced the midpipe with the Roadster and the muffler with the Racing Beat duals. I was able to do it easily by myself and everything fit very well with out any cutting or moding except a small cutout for the 2nd exhaust pipe. I like the sound but it can be a bit dry and raspy before the car warms up fully. If there is a meet at Kellers tomorrow night I will be there and you can try mine.
Hope this helps.
I drive to fast to worry about my cholesterol.
