Results 1 to 11 of 11
Thread: The check engine light keeps coming on in my NA
    Default The check engine light keeps coming on in my NA
    I was driving home from Houston the other day and the check engine light came on in my car. It isn't overheating. Oil pressure is good. No funny noises coming from the engine. No rods hanging out of the side of the block. I drove it today and after it warmed up the check engine light came on again.
    Is there a code reader I can use to find out what's wrong? Does anybody have one?
    yes, i do.
    And Thor wields his hammer in 3... 2... 1...
    Dec 2006
    dallas
    hmmmm
    What year is your car? If it's an OBD-I (pre-1996) a code-reader will be zero help. You'll need a paper-clip and these instructions -
    http://www.miata.net/garage/faultcodes.html
    It's a 93. Looks like the paper clip.
    Chassis Designer
    Apr 2009
    Keller, TX
    Just make sure the gas cap is on correctly. You'd be surprised how often that triggers the malfunction light.
    My stepdad has a scanner/reader that does OBD I and OBD II. Unfortunately, he lives in Oklahoma. But he will be here Friday!
    Quote Originally Posted by motorollow View Post
    No need on an OBDI Miata.
    To test your engine, first start it up and let it reach normal operating temperature. Then shut the engine off and proceed with work at the diagnosis connector. Using an unfolded paper clip, connect the GND and the TEN pins together. Return to the driver's seat and turn your ignition key to "ON" but do not start the engine.
    Observe the "CHECK ENGINE" light in your instrument panel. It will flash a certain number of times to indicate a malfunction in your engine's control system. Count the number of flashes to indicate the malfunction code.
    If the code is a two-digit number, the "tens" digit will be displayed first, then for a short 1.6-second period the light will be dark, then the "ones" digit will be displayed. This will repeat after a four-second dark pause. If there are multiple codes, they will each be separated by a four-second pause and may include two-digit codes, so pay attention.
    Take as long as you need to record the codes and then refer to the chart below or section "F" of your factory service manual.
    Note that the following codes are for '93 and older models. Beginning in '96, the Miata used OBD (On-board diagnostics) which requires a special scanner to read the codes.
    FAULT CODES ('90-'93)
    1 Ignition pulse (No Igf signal)
    2 No Ne signal
    3 No G signal
    8 Airflow meter open or short circuit
    9 Water thermistor open or short circuit
    10 Intake air thermistor in airflow meter open or short circuit
    12 Throttle position sensor open or short circuit
    14 Atmospheric pressure sensor open or short circuit
    15 Oxygen sensor <0.55 V 180 sec after 1500 rpm
    17 Oxygen sensor unchanged after 1500 rpm
    25 PRC solenoid valve
    26 Solenoid valve (Evaporative canister purge)
    34 ISC Valve
    How about checking the car at Keller's tonight? I will be close to home in case of breakage. And if the worst happens I do have a car trailer.
    Did you get a paperclip and read the code?
  1. check engine light woes
    By aalvarez04 in forum Miata Tech and Chat
    Last Post: 09-03-2009, 01:38 AM
  2. Possible reasons for check engine light to come on?
    By cArAzzIE in forum Miata Tech and Chat
    Last Post: 06-17-2008, 01:35 PM
  3. State Inspection, Fuel Cap and Check Engine Light
    By randy7601 in forum Miata Tech and Chat
    Last Post: 07-27-2007, 06:18 PM
  4. Check Engine light part 2
    Last Post: 01-23-2006, 08:47 PM
  5. Check engine light
    Last Post: 01-04-2006, 03:06 PM
