Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Potential Fuel Pump or relay problem?
    How hard or easy is it to get to? Do you just have to remove the back deck carpet and the big cover plate? I'd probably buy a new OEM.
    Yep. It is a 30 minute or less job once you have done it a few times.
    If it were a huge pain in the ass like dropping a full 44 gallon gas tank to replace it like when I did my Suburban, I'd definitely go with a new one. However, since this is a relatively easy enough change I'd opt for used at $75. In the unlikely event you ever have to change it out again you're still ahead.
    Put another worn out one in there, spend $75, and when it fails you can buy a new one.
    Good news - You'll be experienced
    Bad news - you'll be out $200 + $75 and another half hour of your life.
    YMMV
    Driver Keifersmith's Avatar
    Aug 2008
    North Richland Hills, Tx
    Yeah, this is a really easy swap. especially since I hadn't replaced any of the back deck carpet/etc from my recent roll bar install. procrastination paid off
    I'm more concerned with the hassle factor of being stuck on the side of the road if I put in a used one and it goes out after a short time. If the average lifespan of a fuel pump is 200k miles then I'll go OEM since most salvaged ones probably don't have much life left in them. If they're known to last a lot longer, then the used pump will probably still outlast the car and I probably don't need to get to concerned about it.
    90 Red NA
    91 Red NA
    99 Triple Black NB "Dimples"
    Nov 2008
    at the buffet (Frisco)
    I put in a used one from Nissan Mazda heaven and it looked damn near brand new... especially compared to the one I pulled out. Save the $125 and go used.
    It's a pretty easy swap, especially if you've not put everything back together yet.
    New parts can leave you stranded on the side of the road as well.
    Quote Originally Posted by Keifersmith View Post
    But what if the used one was actually an OEM replacement with only a few thousand miles?
    Aug 2008
    Swung by Mazda-Nissan Heaven on the way home from work tonight and picked up a fuel pump from Mario. Took me about 20 min to swap it out and I wasn't in any hurry. Car is back up and running like a champ again. Woo Hoo!! Now I get to go register for Sunday's NTAXS event at Pennington.
    Thanks for all the input and suggestions.
    90 Red NA
    91 Red NA
    So, when you go to Nissan-Mazda heaven in search of a particular part, are they already pulled from teh car, do you have to pull or do they have their own people pull it?
    Quote Originally Posted by AlanP1964 View Post
    They used to let you roam the yard and pull your own stuff. I've been told they won't let you do that now, but haven't been there lately.
  11. #31
    Aug 2008
    They pull the part for you. I called as I left to drive down there and it was already pulled and waiting on me when I arrived.
    90 Red NA
    91 Red NA
  1. Fuel Pump (or Deja' vu)
    By Walsted in forum Miata Tech and Chat
    Last Post: 08-11-2010, 05:50 PM
  2. WTB: 00-05 Fuel Pump
    By goofygrin in forum dfwMiata.com Classifieds
    Last Post: 07-10-2010, 07:50 AM
  3. FS: 190LPH HP fuel pump mounted in 1999 Miata fuel pump bracket
    By 71dsp in forum dfwMiata.com Classifieds
    Last Post: 05-17-2010, 01:01 PM
  4. Name that problem: Fuel pump or TPS or ???
    By mildensteve in forum Miata Tech and Chat
    Last Post: 04-19-2008, 09:06 AM
  5. fuel pump issues
    By saffikeagan in forum Miata Tech and Chat
    Last Post: 02-17-2008, 05:33 PM
